Hi Glenn,
I think I may have found a way to solve my *split into groups from start problem*
However When I set up a forum in the CP~ & than also set up a sub-forum... I find no option to create a post.
Am i missing something ?
I want to set up a number of Sub-forums ~ to which I later want to create posts.
In the posting options section of the CP~ there are 2 options > act a channel or not. The Yes option allows for creation of topics BUT the NO option... makes a sub-channel > just as I want... and so....
If i chose the yes option and then create posts ~ which I then try to convert into a sub-channel, I am told that I can't convert to a sub-channel if it contains posts.
What to do ?
What to do ?
