Follow us icons
    Follow us icons
    Hi.
    Where or how I can add follow us icons to my forums?
    Thanks
    You can use a Static HTML module and place the Follow Us HTML code there.
    You can use the addthis.com service to create the buttons.
      Where I should add then html module
        It's up to you where you want to display the icons. Just use Sitebuilder to add the module and then drag and drop the module to where ever you want to place it.
          Yeah, I know. The question is can I add module next to search bar ?
            To do that, you'd have to create a template hook in header_toolbar hook location.
            If you don't know how to create a product with template hook, there is a tutorial by Joe D of vBulletin aka BirdOPrey5. I linked to his tutorial on my Useful Links module on the homepage here. I called the link "How to create a Basic vB5 Mod".
              Thanks. I will try to make it, and I'll get back with updates.
