Sorry for the delay. I will look into your server tonight.
When clicking on "View Events in Calendar"
Fixed it!
After carefully looking at the source code and database and following the error strack trace, I was able to pinpoint where the issue was.
There were 2 records of the "calendar" route in the database. One was invalid which was the one being used on your site and causing the issue. I renamed it to "Calendar2" (I could have deleted the record but I was afraid to break something else so I just renamed that invalid route) and this fixed the issue.
- Likes 2
I don't think there will be any issue with it on vB upgades.
I'll send you the invoice shortly.Helpful? Donate. Thanks!
Reply to Topic Starter Ribbon for vBCloudby glennrocksvbThanks for reporting. I'll bookmark this post and check the issue.04-22-2024, 06:40 PM
Reply to Topic Starter Ribbon for vBCloudby MitchIt seems since the 6.0.4 update the topic starter is no longer working04-22-2024, 05:02 PM
