Is there a way to embed this webpage within the main site by adding a new page and placing it within an html or php module?
Embed page withing vbulletin
Use an HTML module and place it inside an iframe.Helpful? Donate. Thanks!
There is a way but the CSS used by vB5 might affect and break the CSS used by the gallery page.Helpful? Donate. Thanks!
Not tested by try adding this script on the Chapter Photos iframe page.
Code:<script> (function() { function init() { if (parent != window) { parent.document.getElementById('chapterphtos').style.height = document.body.scrollHeight + 'px'; } } window.addEventListener('load', init); window.addEventListener('resize', init); })(); </script>
No, put it in the <head> tag of the page inside the iframe. Not on the page containing the iframe.Helpful? Donate. Thanks!
Do you see chapter_photos directory?Helpful? Donate. Thanks!
What files do you see in that directory?Helpful? Donate. Thanks!
by MahmoudE9Hello
How are you
After promotion version 6.0.4
I updated the counters and during the update the search index was rebuilt...Today, 06:50 AM -
by matoseHi guys,
Just migrated to vB Cloud and found your forum searching for some customizations.
Nice to meet you!
m...05-03-2024, 01:25 AM
