In vB 5.4.0, they introduced SVG icons. Here's a tutorial on how to hand code SVG so that you can create your own custom SVG icons you can use in your forum.
How to Hand Code SVG Tutorial
What You'll Be CreatingOne of the great things about scalable vector graphics (aside from their being infinitely scalable without quality loss) is that once you know the fundamentals you can...
