Make Forum Statistics Module Rock! (vBCloud compatible)
    The issue occurs when the module content is not wide enough to fit the percentage used in the CSS. So you have to adjust it to find the perfect value that will work in any device.
    My Amazon Affiliate Link ​
      I like this a lot. I'm messing around adding some shadow to the text.
      .widget-stat-number {
          text-align: center;
          text-shadow: 1px 1px 2px black, 0 0 25px #fcd112, 0 0 5px #005157;
          font-weight: bold;
          font-size: 20px;
          color: #eb6d00; /* adjust color as needed or remove if you want the default color */
      .widget-stat-label {
          text-align: center;
          text-shadow: 0 0 25px #fcd112;
      Thanks, Glen
      Click image for larger version  Name:	coffee_icon.png Views:	1 Size:	9.9 KB ID:	16557 sent
      • Kavala
        Thanks!
      Thanks!
      ginger beer GIF
        Possible to fit this here?
          Did you mean to make the font size gigantic to fit the available width?
        As i removed from showing "active_members_x" would it be complicated to center member count?
          goxy63, add this custom CSS in css_additional template or CSS Editor in Sitebuilder.
          .widget-stat-item:nth-child(3) {
              margin: 0 auto;
              display: block;
          Remember to remove this code when you decide to display the active members count.
            Thank you, works just great
            Cheers
              Cheers
              Good suggestion.
              And thanks, Glen!
                it works perfect
                deserve coffee full of sugar (F)
                  Hi,
                  I'm not finding the phrases here. Have the instructions changed maybe? I'm on VB 5.5.1.
                    I don't think phrases have changed. But I can't confirm.
                    Did you search by phrase variable and not by phrase text?
                      amazing modification.
                      does this modification is compatible with 5.5.5?
                        Hi glennrocksvb this module is a bit bugy when accessing from my Ipad, is there a way to fix it? Thanks
                          Just curios what issues are you having on the Ipad? Mine seems to be working fine
                        #29
                        Fixed myself Mitch
                          Nice mod. Thanks.
                          Works in vB 5.6.0.
