Icons in drodown usercp menu
    This product add icons in the usercp menu.
ID:	9951Click image for larger version
    It was created using existing code found on vborg that required 1 template edit and the rest put into additional.css and to be honest i did not fancy doing the edits over and over again as i have about 15 test sites in various stages of development and 2 live sites all with at least 18 themes that is a lot of editing to do.
    It was originally posted for vb5.2.2
    The product was made on vb5.4.1 beta 1 so should work on earlier versions
