Ok here is the first product i have created it adds breadcrumbs in the footer works on vb5.4.1 alpha 4 may work in other versions not tried it on other
Breadcrumb in footer
Thanks for sharing
product_footer_breadcrumbs.3.zip Updated too next version with a few tweaks.
Normal breadcrumb
Updated breadcrumb
I suggest to make this minor CSS tweak to make the > separator vertically centered.
Code:#breadcrumbs .separator { margin-top: 8px; }
Try this generic solution:
This will only display the footer breadcrumbs if there are breadcrumbs on top.Code:#footer #breadcrumbs { display: none; } #breadcrumbs ~ #footer #breadcrumbs { display: block; }
