Display Edit Avatar Popup By Default if User has no avatar yet
    Free Mod Display Edit Avatar Popup By Default if User has no avatar yet
    This vB5 mod makes uploading a user avatar a little bit easier by automatically opening the Edit Avatar popup by default when visiting the user profile page. It will only trigger the popup if user has not uploaded their custom avatar yet.
    Notes:
    • This mod is only compatible with self-hosted version of vB5. If you want a vBCloud compatible version, you can find it here.
    • This is a FREE mod without vbmods.rocks branding. Any donation is welcome and appreciated.
    • This does not require editing existing vB5 templates but it requires uploading XML file to install this product. If you are not comfortable doing this, you could purchase product installation service from us by clicking the button below.
    vBulletin One-Time Plugin Installation Service Add-On: $20
    Purchase this product add-on to get one-time professional installation of this mod from us.
    v1.2
    • Fixed a bug where the Edit Avatar popup was not appearing for users without custom avatar if the default avatar image file was changed by the site owner.
    • Fixed a bug where Edit Avatar dialog was not appearing on load of Profile page.
    • Initial version
    Download the zip file below. Uncompress the file and then follow the installation instructions in the readme.txt file. Enjoy!
    Works like a charm!
      Perfect operation thanks for your work
      A cordial greeting
        Thanks Fleiding and chicoynano!
          awesome, i love this
            Glenn I would like a Cloud version of this when you're done the "to the top" one
            thanks
              thanks glen download coffee on the way will install let you know the outcome
                installed work great coffee send it as usual lovely job
                  Is it possible to have a screen shot?
                    The Edit Avatar popup is the existing popup. The only change is it automatically opens when you visit your profile page and you don't have avatar yet.
                      Gotcha!
                        screen shot profile/avatar/
                        Edit Avatar popup
                        browser avatar of you choice save done
                          Thank you voyger thats what I was understanding with what glennrocksvb explained. I hadn't been able to understand exactly what was popping up (I was expecting something different) apart from that which we see when we want to change our avatar. Both of you explained it well.
                            Glenn
                            Anything yet for the cloud version?
                            Thanks
                              Will look into it.
                            Doesn't work. Looks like mods from here doesn't work with my vbulletin forum
