Search feature on websites not just in forums is one of the most important features a website must have. Giving the website visitors the ability to easily find the information they are looking for is critically important especially in forums where there are tons of user-generated content to sift through.
Having said that, I'm sure we can all agree that in general internal forum search is not as powerful as Google Search. Not surprising as Google knows everything (it can index)!
For those of you who owns a vBulletin 5 or 6 forum and doesn't like the limited feature of vB keyword search, there's a way to power keyword searches within your forum with Google Search.
Previously you could use Google Site Search to use Google to search your site with customizable design to match the look and feel of search results with your website. But unfortunately, Google has discontinued sale/renewal of the Google Site Search since April 1, 2017 and it will be completely shut down by April 1, 2018.
But don't worry, there's still a way for you to use Google Search within your forum with this mod albeit without customizable design and other features Google Site Search offered.
Advantages of using Google Search to power your keyword search in your forum:
Notes:
Download the zip file below. Uncompress the file and then follow the installation instructions in the readme.txt file.
- Better search algorithm than internal search.
- Can include short and common words. vB5 and vB6 strip these in the default vB Search.
- Vast Google Search tips and tricks will be available in your forum.
- Use quotes to search for an exact phrase
Yields only results with the same words in the same order as what's in the quotes. Very useful if you are searching for a specific phrase. - Use an asterisk within quotes to specify unknown or variable words
For example, "* is thicker than water" may yield results such as "blood is thicker than water" and "love is thicker than water". - Use the minus sign to eliminate results containing certain words
For example, jaguar -car will yield results containing the animal jaguar and not jaguar the car. - ...and many more!
- Users can do Images or Videos search by clicking Images or Videos tab in the Google search results.
- Offloads your server with keyword search requests.
- Not useful for private forums as Google cannot index the private pages.
- Your site will lose branding to Google on search result pages. Users are taken out of your site and redirects to Google search results page.
- Google will only search indexed pages in your forum. Recent content from your forum may not be instantly available until Google indexes it.
- Compatible with vB5 and vB6 (self-hosted)
- Not compatible with vBCloud. A vBCloud version could be created if there are demands for it.
Notes:
- This mod replaces the default Search box in the header in vB5 and vB6. This does not replace the Advanced Search page. Using this mod will lose the link to the Advanced Search page anyway. That can only be reachable if you know the URL.
- This is a FREE mod without vbmods.rocks branding. Any donation is welcome and appreciated.
- This does not require editing existing vB5 templates but it requires uploading XML file to install this product.
