Are you caching templates as files? If yes, turn if off and save and then turn it back on again. vB has a bug where it caches the old mod templates even after an updated mod templates are installed.
Hop la V2 du meilleur thread de CPC.
La V1 est ici. (http://forum.canardpc.com/threads/24669-Bande-dessin%C3%A9e-sortie-de-l-Oeil-de-la-Nuit-T2-le-27-05-!?)
La Bédéthèque idéale des canards (au moins un canard aime, faites attention aux experts cpc !)
La meilleure série
- Donjon de Sfar, Trondheim et al
- La Brigade
If you go to last page, use the pagination at the bottom to go back to 306 for example, the dropdown doesn't update on its own .
Edit: and now it doesn't do the bug anymore. Grmbl.
Come avevamo annunciato vogliamo creare un thread dedicato al fucile semiautomatico Beretta A 300/303 e alle sue variazioni come gli AL1-2-3 i Browning B 80 e i Breda Altair, Aries 2, ecc.
Cominciamo da un fucile molto raro e davvero speciale.
Si tratta del Beretta AL3, una versione di A301 per gli USA, inciso a mano, con
How can you navigate to a page in between those ranges using the dropdown if the listed pages are ranges instead of individual pages? Each page number has to be listed in the dropdown so you can choose one.
You can keep that setting to allow for the colon character application-wide in the request path. And then add this URL Rewrite setting to reject request...
