Forum Moderator List
    Paid Mod Forum Moderator List
    This Forum Moderator List plugin displays the moderators for each forum in the forum list. This is a missing feature in vBulletin 5 by default.
    With Username Only
    Click image for larger version  Name:	moderatorlist.png Views:	1 Size:	22.7 KB ID:	5286
    With Avatars Only:
    Click image for larger version  Name:	moderators-list.png Views:	305 Size:	52.9 KB ID:	23787
    1. Has an option to enable/disable mod.
    2. Has an option to display avatar or username.
    3. Adheres to Username HTML Markup option if configured in the Usergroup Manager.
    4. Does not require editing existing vB5 templates as it uses uses Products & Hooks system.
    5. Compatible with PHP 8.
    Style Customization
    By default, avatar size is 19px by 19px. If you want to change it, add this in css_additional template:
    #vb-page-body .vbmodsthatrock-moderator-list .avatar > img {
        max-height: 32px !important;
    Adjust the value accordingly. For other customizations, please see included readme file.
    • Compatible with vB5 and 6 (self-hosted)
    • Not compatible with vBCloud.
    Screencast Demo
    See video screencast below:
    Live Demo:
    See homepage on this site. Notice I customized the style to display the moderator list in grayscale color by default to prevent it from being too noticeable that it takes away focus to the main content in that block which is the forum title and description. Then on hover anywhere in a forum row, it removes the grayscale color for that selected forum and displays the moderator list in its original color.
    Version History
    v1.2
    • Added support for Name Card where clicking username or avatar link displays the Name Card popup.
    • Support for RTL languages in terms of layout.​
    • Added an option to enable/disable the mod.
    • Added an option to display avatar or username.
    • Fixed alignment issue of the moderator list.
    • Initial version.
    Price 1:
    $15 (with vbmods.rocks branding in the footer)
    Price 2:
    $40
    ($15 base price + $25 branding-free)
    Hey I just bought this plugin, but the more I think about it, I'm not crazy about the mods' names showing up first before the categories. Is there a way to make them show up on the individual forums but not the first page? Or, if not.... maybe under the categories?
      You can hide them on homepage using custom CSS in css_additional.css.
    Hmm. I installed the pluggin but it isn't working. I haven't written any additional code - just put it in exactly how you did in the video, minus the color change. The names aren't showing up. I have already set up moderators for each channel.
      Did you follow the installation instructions completely? Including step 2 which is to upload the contents of the 'upload' folder to your server?
      • Archetribe
        Thanks I didn't see this step in the video after watching it two more times, but I put it into the server the way it was listed and it worked. I appreciate the feedback
        That part is not included in the video. You should always reference the included installation instructions document.
      Never mind this post - I figured it out.
        A question about customisation from a non-coder. The plugin has included administrators as well as moderators. I gather I can control that via css_adittional but I don't know what the syntax for that would be? In our case administrators are in group 6 and moderators group 7. As we're and upgraded forum from 3.8 there are no channel moderators configured.
        Edit: I figured it out. It was a carryover from how things were set up in 3.8 with moderators, in reality administrators, set at the 'forum' level inherited downwards. removed them and it looked better.
          Hi,
          1) Does this mod work on vB 5.6.6 / PHP 8?
          2) Is it possible to replace moderator links with small 16x16px avatars for example. Two moderators maximum per forum.
          Regards
            lange
            1. Yes
            2. Not at the moment.
              Will release a new version soon that gives an option to display avatar or username.
            Released v1.1 to support displaying avatar only. First post updated and customers notified.
              Thanks for the update.
              Do you have a demo or a screenshot with the avatars?
                lange, I attached a screenshot in the first post.
                  Hi,
                  PHP 8.0.15 / vb 5.6.6
                  This mod seems to work everywhere even in the other pages of forum.
                  To save me time, could you point me to the place where we can modify the CSS (size, padding, margin, top...) for the avatars?
                  Thanks in advance.
                    There is a "Style Customization" section in the first post that shows how to customize the avatar style.
                  Just bought this. This is my first buy from you.
                  I can say, this is the bomb!!!!!
                  More and more my vb5 is going to look / have the features that i had on vb4.
                  Install went perfectly!!!
                  Thank you Glenn for all your work!!!
                    Thanks for your purchase adama! You've earned the Certified Buyer badge on your postbit.
                  hy Glenn
                  as expalined in other mod topic (last registered users) with namecards setted on i can not see the namecard clicking moderator name in this mod.
                  thanx
                    OK, thanks! I bookmarked this post and added it to my todo list.
