Hi Glenn,
I came across this post on the vBulletin Community and - although it was a quite old post - decided to try the hook on my forums. It does display the Visitor Messages Tab, but when you click on the tab, you'll get an invalid page.
Do you think you can update this hook to get it working? Will it display ALL Visitor Messages or does it the same when you filter on Only Visitor Messages and select All Times?
Thanks,
Rob
Thanks,
Rob
