Timed Sticky That Rocks
    Paid Mod Timed Sticky That Rocks
    There are cases when you have a time-sensitive sticky topic that would only make sense to be a sticky for a particular period of time. This timed sticky mod allows you to do that.
    Here are examples:
    • You have a sticky poll for Mother's Day. So you'd want it to be only stuck until May 14th.
    • You have a sticky Upcoming Event topic. So you'd want it to be only stuck until that event comes.
    • You have a sticky topic specific for Christmas. So you'd want it to be only stuck until December 25th.
    Screenshots:
    1. Integrates with existing Inline Moderation and adds "Set Timed Sticky" to the inline moderation submenu.
    2. Can timed stick multiple topics at a time in the Forum Display page as well as a single topic in the Topic Detail page.
    3. Existing "Stick Topic" inline moderation will still work as is. So you can still make a topic a regular sticky without time sensitive limitation.
    4. Existing "Unstick Topic" inline moderation will still work as is, plus it will also work with timed sticky posts to unstick them manually as needed.
    5. Displays sticky date for Administrators (and whoever has permissions for inline moderation) or topic author only.
    6. Uses the Plugin/Product system, no template editing required.
    7. Uses the API system to create custom API that provides interface to the frontend to update timed sticky data.
    8. Uses the Scheduled Task system to automatically run script every hour to unstick timed sticky posts.
    9. Uses Phrase system to allow for easy translation to your own language.
    10. Creates its own table in the existing vB5 database to store timed sticky data.
    Instructions:
    Price: $50
    Check this out! This mod was originally requested by Deepblue and is now implemented.
      Thank you bro, you are the best. Your approach to people is very kind and helpful. Actually i was pissed of by vBulletin's Developers attitude and was considering leave vB and start using Xenforo but your help, work, effort and kindness made me think about this again. If i am going to stay on vBulletin that would be because of you.
      • NumNum
        I too was at that point.
      Thanks for your kind words Deepblue.
        If you want me to create more mods for vB5, please vote for this JIRA to add more PHP hooks.
        ​​​​​​​http://tracker.vbulletin.com/browse/VBV-17168
          Voted mate.
            Voted!
              Voted too!
              HostXNow - UK Web Hosting
