How to find hidden links to visitors
VBulletin5 unregistered member hiding link how ?
What did you exactly mean?
Did you mean you want to hide links in the posts from guests including search bots?
I see 2 possible "hacky" solutions to this and each has its own advantages and disadvantages.- Client-side
- Removes links in posts dynamically using Javascript.
- Survives upgrades. No need to re-apply mod after upgrading vB.
- Guests can't see the links.
- Search engines can still see the links. Might be good for external links and bad for internal links?
- Web savvy users might still figure out the links. But for average users, they might not.
- Server-side
- Removes links in posts dynamically using PHP.
- Does not survive upgrades. Need to re-apply mod after upgrading vB.
- Guests and search engines can't see the links.
Which solution do you prefer?
- Client-side
Well it's not something I currently need, I just thought there might be a solution that did not require an actual modification.Originally posted by glennrocksvb View PostI see 2 possible "hacky" solutions to this and each has its own advantages and disadvantages.- Client-side
- Server-side
The above "hacky" solutions take into consideration that currently vB5 lacks suitable PHP Hook location to be able to create an elegant solution.
If you had a solution that didn't, I'm sure it would be valuable to some users. That's why I asked. It's not a big deal or anything though. Thanks for the response.
EDIT: I just noticed for client side you put that there's a way with javascript. Sounds interesting.
- Client-side
There's no BBCode settings to hide a BBCode from guests. So either solution would require some sort of a mod or plugin. Even if there was a suitable PHP Hook location, it would still require a mod.
How about something similar that allows us to hide phone numbers and/or email addresses from unregistered users.
Because users enter their phone numbers in different ways, we'd need to make sure it had the ability to recognize different user formatting, example: 555-555-1234 or (555)555-1234 or 555-1234. Of course, you can this a step further by adding the number 1 in front of the examples.
Users shouldn't post personal information such as phone numbers and email addresses in a public forum. But to answer your question, there is no BBCode for both so it would be harder as you would have to create a script that parses the content to find a phone number and email looking text in a post.
