Random Image Ad Banner System
    Paid Mod Random Image Ad Banner System
    This vBulletin 5/6 mod displays random banner ad on top of every page. It features banner management (add, edit, delete) and simple analytics like impresssions and clicks.
    • Compatible with vB 6.x (self-hosted)
    • Compatible with vB5.7.x (self-hosted)
    • Not compatible with vBCloud as it requires installing custom PHP script and adding a new database table for the management of the banner ads.
    Custom CSS:
    If a Notice is present on top of the page and if it touches the ad banner, then you need to add the below custom CSS in css_additional.css template to add spacing between the notice and the ad banner. Adjust the value accordingly.
    #notices ~ .vmtr-random-banner-container {
        padding-top: 20px;
    Version History
    v1.2
    - Fixed bug where the site breaks if there are no banner ads created yet.
    - Fixed compatibility with vB 5.7.x and vB6+
    - Initial version​
    Price: $50 (without vbmods.rocks branding)
    Watch the screencast demo video below:
    My Amazon Affiliate Link ​
    I am really happy with this mod .. Thank you Glenn
    this is truly fantastic !
      Any way to add in side banner ad management as well?
        This would require substantial additional coding to implement that.
          Is this module mobile responsive so the banner width shrinks accordingly?
          Also, if I purchase the unbranded version for $50, can I use it on all three of my forums without paying extra fees or is a license for only one forum at a time?
            Yes it is responsive. It is shown in the video screencast demo at 1:34 in the first post.
            Yes you can use to forums you own.
          when I try to upload banner image, it say error ?
            any plans to fix this mod ?
              did any one saw glennrocksvb recently ?
              I have problem with this mod
                  Dear glen,
                  can you please fix this add-on to make it work?
                    glennrocksvb
                      Will look into this. Thanks!
                        The mod is using move_uploaded_file PHP function to upload the file to the server. The mod displays that error message when that function failed to upload the file for some reason. Please check your server logs to see if there is any log entries related to this.
                          And did you create the "random-banner" directory under the "images" directory and does it have the correct write permissions as described in the installation instructions?
                            it was issue with permission, it works with 777!
                            thank you very much and welcome back!
                              Glad to help!
