Registration Security Token Fix
    Free Mod Registration Security Token Fix
    There is a known bug (VBV-15477) in vB5 (starting 5.1.9 PL3) wherein after a new user registers, it displays raw phrase variable(s) in the confirmation popup instead of the translation text. If your forum has Paid Subscriptions, the payment order form which appears after a successful registration will not display due to the same issue. This is a major issue as it will prevent the user to pay for the subscription!
    Note: This issue is officially fixed in version 5.2.0. If you are running that version or newer, you don't need this mod.
    Installation Instructions:
    Please refer to the installation document included in the download file.
