Text inside button (should be vb.cloud compatible)
    Creating a button effect with text inside you use css then place it inside the additional.css for each theme that you use which can be a little tedious if you use a lot of themes what i have done here is created a collection of different css styles some are modified from existing styles from a post i seen over in vb.com by Mark.B (with full credit given in the footer) and a couple i created myself and created a product then when you create the prefix entering the prefix title in the Title (Rich Text) simply enter the code below.
    <span class="prefix prefixGold   ">[COLOR=#FF0000]title[/COLOR]</span>
    Changing the highlighted text to whatever you want to use below is a full list of the codes you can use.
    <span class="prefix prefixOrange  ">title</span>
    <span class="prefix prefixSkyBlue  ">title</span>
    <span class="prefix prefixLightGreen  ">title</span>
    <span class="prefix prefixYellow  ">title</span>
    <span class="prefix pprefixLightSalmon  ">title</span>
    <span class="prefix prefixMaroon  ">title</span>
    <span class="prefix prefixTeal  ">title</span>
    <span class="prefix prefixCherryRed   ">title</span>
    <span class="prefix prefixGold   ">title</span>
    <span class="prefix prefixGrad   ">title</span>
    Included in the zip is a text file with the codes used
    Here i the the outcome of the way they will appear.
    Click image for larger version  Name:	prefixset.png Views:	1 Size:	37.7 KB ID:	11842
