Custom Icons
    Custom Icons
    This addon replaces the standard speech icons on your forum with a custom icon that you can create and placed in the images/customicons directory with the filename of,
    oldpost.png where the forum has no new posts
    newpost.png where new posts have been made
    Click image for larger version  Name:	icons.png Views:	1 Size:	311.6 KB ID:	11207
    I added my own icons (read and unread), but I have to adjust the dimensions as well. Don't know what dimensions I can use because my icons are .svg files.
      I am using 42x42px
        What are you using to create your icons?
        • willie53
          I use Photoshop for all my graphics
        Two comments:
        First of all that's Glenn's code you used to create this product, which is illegal unless you had his express permission, and even then he should have been given an author credit in the product. He wasn't. I checked.
        Secondly, vBulletin is releasing a version where the icons can be changed directly in the admincp so this is a temporary fix at best.
          Originally posted by inomnibus View Post
          Two comments:
          Code amended
