You don't need a plugin you add your domain to Cloudflare and in your includes/config.php you replace
/* #### REVERSE PROXY IP ####
If your use a system where the main IP address passed to vBulletin is the address of a proxy server
and the actual 'real' ip address is passed in another http header then you enter the details here
Enter your known proxy servers here. You can list multiple trusted IPs separated by a comma.
You can also use the * wildcard (at the end of a definition only) or use the keyword 'all' to represent any ip address.*/
//$config['Misc']['proxyiplist'] = '127.0.0.1, 192.168.*, all';
/* If the real IP is passed in a http header variable you can set the name here; */
//$config['Misc']['proxyipheader'] = 'HTTP_X_FORWARDED_FOR';
with
$config['Misc']['proxyiplist'] = 'all';//127.0.0.1, 192.168.*,
//$config['Misc']['proxyipheader'] = 'CF-Connecting-IP';
