Problems with all APPLE users
    Appears that all iPhone, iPad, apple computer..... users....
    Are able to put only first letter (on titles or in login tab) and then... NOTHING..... (navigation get well, 'only' this issue). (forum www.daidegasforum.com VB 5.3.4 )
    What can it be? We have some mod of graphic (by glenn).... maybe proportion of layout?
    Does it also happen here or in vbulletin.com?
      Only on www.daidegasforum.com
        Maybe.... is possibile to set a VERY SEMPLIFIED VB5 style for users that come from TAPATALK and SAFARI (or Apple ) ?
          Not possible. But even if it is, it's not a good solution.
          Does the issue also happen in non-customized vBulletin themes?
            On daidegasforum? I try.....
            But some hooks .... personalizes all the styles... like social login...
              Try disabling that plugin temporarily to see if the issue goes away.
            With disabling.... ALL THE SAME:... maybe is something on css.....
              I've created a news style... with no parents.... but all the customization were reported.....
              It's possibile to erase all personalizations, hooks, css in a determinated style? To restart from zero..... only in a determinated style?
                You cannot disable hooks per style. It's disabled in all styles. However, you can also disable hooks in config.php for a specific IP address only. Take a look at this topic:
                Debug mode is useful for debugging/development purposes. A vBulletin support staff has a blog (http://www.vbulletin.com/forum/blogs/how-to-enable-or-disable-debug-mode-in-vbulletin-5-x-vb5-debug-mode/4013846-how-to-enable-or-disable-debug-mode-in-vbulletin-5-x-vb5-debug-mode) about it. You can follow his instructions but if you
                  Ok.. but..... it's better to resolve the issue.... I don't know the ip address of the users with apple.... thanks.
                    It's part of resolving the issue by isolating the issue and by process of elimination. The cause of the issue is hard to pinpoint without doing this process of investigation.
