I created a transparent logo for my default theme and it looks great. When I switch themes to Wood for example, the logo is no longer transparent and appears distorted. Do I need to create a custom logo for each theme?
Header Logo for each template?
Did you set the titleimage stylevar to set the logo? You have to set the same in other themes/styles you are using.Helpful? Donate. Thanks!
Yes, I applied the image to all styles. There is an option to apply to all styles in sitebuilder when you upload the image. The titleimage stylevar is also correct for the theme. Maybe since the Wood theme has a dark brown header background and the transparent image doesn't look good on a dark background?
Edit: It must be the image. I'll test it with another one.
Comment on Topic Starter Ribbon for vBCloudby glennrocksvbThanks for confirming the fix works.Today, 08:20 AM
Reply to Topic Starter Ribbon for vBCloudby glennrocksvbI have updated the template code in the first post. Please try it again.Today, 06:38 AM
