I have an issue with overlapping modules on my home page. SiteBuilder > Edit Page > Default Forum page template shows several modules in the narrow portion of the layout, but the homepage displays 1 giant module. Nothing happens when I click the garbage can, and reverting all styles does nothing. Is there a way to get the forum page template back to it's default state?
Overlapping modules
Which giant module were you referring to? Where are the overlapping modules?Helpful? Donate. Thanks!
I narrowed it down to the trending topics and static html modules. I had to disable PHP, Static HTML, and Ad Module rendering to remove them. That seems to have fixed it but I have another issue on a different forum. I'll start a new topic for it.
Reply to Topic Starter Ribbon for vBCloudby glennrocksvbI have updated the template code in the first post. Please try it again.Today, 06:38 AM
Reply to Topic Starter Ribbon for vBCloudby MitchGood Day Glenn!! I implemented the above hook #1-#10. My font style and size changed when typing a reply to a post. Not sure if it also changed in other...Today, 03:25 AM
Reply to Topic Starter Ribbon for vBCloudby glennrocksvbMitch I've added the fix for this mod. Please refer to the "Fix for vB 6.0.4 and later" section in the updated first post....Yesterday, 10:26 PM
