Avatar size
    Avatar size
    Hi Glenn,
    I have changed the max avatar size in /core/includes/class_core.php, used additional css and changed usergroup settings to change the default avatar size to 150 x 150 pixels. When a member changes his avatar, it is displayed as 150 x 150 in his profile, but as 100 x 100 in threads. When I move the avatars from the file system to the database and back, they are displayed correctly.
    What can I do to fix this issue? Is there are scheduled task I can run?
    Thanks,
    Rob
    Try running AdminCP > Maintenance > General Update Tools > Rebuild Custom Avatar Thumbnails
      I get the message that the custom avatar thumbnail directory is not writable, which is strange because I am certain that it is.
        Are you looking at the correct directory?
      • Fleiding
        Fleiding commented
        /core/customavatars
      I still haven't figured out the issue that when members upload a new 150 x 150 avatar, it get's displayed as a 100 x 100 avatar. When I move the avatars from the file system to the database and back, they are displayed at 150 x 150.
      I use the following custom CSS:
      .l-desktop .b-avatar--m > img {
          max-height: 150px;
          max-width: 150px !important;
      .l-desktop .b-avatar--m {
          height: 100%;
          width: 100%;
      Is there a way to fix this? Please note that some members are using avatars of 100 x 100, 80 x 80 and other sizes, so they should not be enlarged to 150 x 150.
        Is this issue consistently happening? When does it happen, when members upload an avatar for the first time?
          It's consistently happening, not only when members upload a avatar for the first time.
            Do you know if there is a cron job I can run which moves avatars to the database and then back to the file system every 24 hours or so?
              Uhh yess, those little avatars are my first mission too.
                I no this is a older thread but i have the same problem and im positive its set to 777
                  Change the folder.. move it somewhere else... sometimes it works. The Update Avatars thingy is sooooooo buggy
                    So after some digging in... the actual code in vBulletin is:
                    PHP Code:
                    if ($vbulletin->options['usefileavatar'] AND !is_writable($vbulletin->options['avatarpath']))
                    But somehow vBulletin ALWAYS seems to be confused whether the avatars are actually inside the DB or just filesystem... the actual PHP is_writable function... is functioning correctly.
                    In any event, to actually resize the avatars (once you've set a custom size in the defines) the "Rebuild" does.... NOTHING. Well not for me.
                    I've written a script to go through all of them and correctly resize per my liking. I can share if anyone is interested.
                    • Papa Bear
                      Papa Bear commented
                      yes please share..
                    Ok, here goes...
                    First file: updateavatars.php - upload it somewhere on your server, and update the DB connection info and file paths as needed as well as the image size.
                    PHP Code:
                    <?php
                    ini_set
                    ("include_path"'/home/xxx/path/toforum:' ini_get("include_path") );
                    include(
                    "resize_class.php");
                    if (!isset(
                    $_REQUEST['startAt']))
                    $startAt 0;
                    else
                    $startAt $_REQUEST['startAt'];
                    $perPage 30;
                    /* DataBase Settings */
                    $HostnameBD 'localhost';
                    $UserBD 'xxx';
                    $PassBD 'xxx';
                    $NameBD 'xxx';
                    $conexiune = @mysqli_connect($HostnameBD,$UserBD,$PassBD) or die(mysql_error());
                    mysqli_select_db($conexiune,$NameBD) or die(mysql_error());
                    mysqli_set_charset($conexiune,'UTF8');
                    $avatarPath './customavatars/';
                    clearstatcache();
                    if (!
                    is_writable($avatarPath))
                    die(
                    'custom_avatarpath_not_writable');
                    $query "SELECT user.userid, user.avatarrevision, customavatar.filedata, customavatar.filename, customavatar.dateline, customavatar.width, customavatar.height FROM customavatar AS customavatar INNER JOIN user AS user ON(user.userid=customavatar.userid) WHERE customavatar.userid >= ".$startAt." ORDER BY customavatar.userid LIMIT ".$perPage.";";
                    $result mysqli_query($conexiune,$query);
                    if (
                    $result && mysqli_num_rows($result) > 0) {
                    while (
                    $currentRow mysqli_fetch_assoc($result)) {
                    echo
                    $avatarPath.$currentRow['filename'].' -> '.$avatarPath.'thumbs/'.$currentRow['filename'];
                    // *** 1) Initialise / load image
                    $resizeObj = new resize($avatarPath.$currentRow['filename']);
                    // *** 2) Resize image (options: exact, portrait, landscape, auto, crop)
                    $resizeObj -> resizeImage(124124'crop');
                    // *** 3) Save image
                    unlink($avatarPath.'thumbs/'.$currentRow['filename']);
                    $resizeObj -> saveImage($avatarPath.'thumbs/'.$currentRow['filename'], 93);
                    $startAt $currentRow['userid'];
                    echo
                    '<hr/>';
                    else
                    die(
                    "Error SQL");
                    echo
                    '<META HTTP-EQUIV="Refresh" CONTENT="0; URL=https://www.xxx.ro/xxx/updateavatars.php?startAt='.$startAt.'">';
                    Second file: resize_class.php
                    PHP Code:
                    <?php
                    # Requires : Requires PHP5, GD library.
                    # Usage Example:
                    # include("resize_class.php");
                    # $resizeObj = new resize('images/cars/large/input.jpg');
                    # $resizeObj -> resizeImage(150, 100, 0);
                    # $resizeObj -> saveImage('images/cars/large/output.jpg', 100);
                    class resize
                    // *** Class variables
                    private $image;
                    private
                    $width;
                    private
                    $height;
                    private
                    $imageResized;
                    function
                    __construct($fileName)
                    // *** Open up the file
                    $this->image $this->openImage($fileName);
                    // *** Get width and height
                    $this->width = @imagesx($this->image);
                    $this->height = @imagesy($this->image);
                    private function openImage($file)
                    // *** Get extension
                    $extension strtolower(strrchr($file'.'));
                    $img imagecreatefromstring(file_get_contents($file));
                    /*switch($extension)
                    case '.jpg':
                    case '.jpeg':
                    $img = imagecreatefromjpeg($file);
                    break;
                    case '.gif':
                    $img = imagecreatefromgif($file);
                    break;
                    case '.png':
                    $img = imagecreatefrompng($file);
                    break;
                    default:
                    $img = false;
                    break;
                    return $img;
                    public function resizeImage($newWidth$newHeight$option="auto")
                    // *** Get optimal width and height - based on $option
                    $optionArray $this->getDimensions($newWidth$newHeight$option);
                    $optimalWidth $optionArray['optimalWidth'];
                    $optimalHeight $optionArray['optimalHeight'];
                    // *** Resample - create image canvas of x, y size
                    $this->imageResized imagecreatetruecolor($optimalWidth$optimalHeight);
                    imagecopyresampled($this->imageResized$this->image0000$optimalWidth$optimalHeight$this->width$this->height);
                    // *** if option is 'crop', then crop too
                    if ($option == 'crop') {
                    $this->crop($optimalWidth$optimalHeight$newWidth$newHeight);
                    private function getDimensions($newWidth$newHeight$option)
                    switch (
                    $option)
                    case
                    'exact':
                    $optimalWidth $newWidth;
                    $optimalHeight$newHeight;
                    break;
                    case
                    'portrait':
                    $optimalWidth $this->getSizeByFixedHeight($newHeight);
                    break;
                    case
                    'landscape':
                    $optimalHeight$this->getSizeByFixedWidth($newWidth);
                    break;
                    case
                    'auto':
                    $optionArray $this->getSizeByAuto($newWidth$newHeight);
                    break;
                    case
                    'crop':
                    $optionArray $this->getOptimalCrop($newWidth$newHeight);
                    break;
                    return array(
                    'optimalWidth' => $optimalWidth'optimalHeight' => $optimalHeight);
                    private function getSizeByFixedHeight($newHeight)
                    $ratio $this->width $this->height;
                    $newWidth $newHeight $ratio;
                    return
                    $newWidth;
                    private function
                    $ratio $this->height $this->width;
                    $newHeight $newWidth $ratio;
                    return
                    $newHeight;
                    private function
                    if (
                    $this->height $this->width)
                    // *** Image to be resized is wider (landscape)
                    elseif (
                    // *** Image to be resized is taller (portrait)
                    else
                    // *** Image to be resizerd is a square
                    if (
                    $newHeight $newWidth) {
                    } else if (
                    } else {
                    // *** Sqaure being resized to a square
                    return array(
                    private function getOptimalCrop($newWidth$newHeight)
                    $heightRatio $this->height $newHeight;
                    $widthRatio $this->width $newWidth;
                    if (
                    $heightRatio $widthRatio) {
                    $optimalRatio $heightRatio;
                    } else {
                    $optimalRatio $widthRatio;
                    $optimalHeight $this->height $optimalRatio;
                    $optimalWidth $this->width $optimalRatio;
                    return array(
                    private function crop($optimalWidth$optimalHeight$newWidth$newHeight)
                    // *** Find center - this will be used for the crop
                    $cropStartX = ( $optimalWidth 2) - ( $newWidth /);
                    $cropStartY = ( $optimalHeight2) - ( $newHeight/);
                    $crop $this->imageResized;
                    //imagedestroy($this->imageResized);
                    // *** Now crop from center to exact requested size
                    $this->imageResized imagecreatetruecolor($newWidth $newHeight);
                    imagecopyresampled($this->imageResized$crop 00$cropStartX$cropStartY$newWidth$newHeight $newWidth$newHeight);
                    public function saveImage($savePath$imageQuality="100")
                    $extension strrchr($savePath'.');
                    $extension strtolower($extension);
                    switch(
                    $extension)
                    case
                    '.jpg':
                    case
                    '.jpeg':
                    if (
                    imagetypes() & IMG_JPG) {
                    imagejpeg($this->imageResized$savePath$imageQuality);
                    break;
                    case
                    '.gif':
                    if (
                    imagetypes() & IMG_GIF) {
                    imagegif($this->imageResized$savePath);
                    break;
                    case
                    '.png':
                    // *** Scale quality from 0-100 to 0-9
                    $scaleQuality round(($imageQuality/100) * 9);
                    // *** Invert quality setting as 0 is best, not 9
                    $invertScaleQuality $scaleQuality;
                    if (
                    imagetypes() & IMG_PNG) {
                    imagepng($this->imageResized$savePath$invertScaleQuality);
                    break;
                    // ... etc
                    default:
                    // *** No extension - No save.
                    break;
                    • Papa Bear
                      Papa Bear commented
                      very cool thanks..
