What version of Jquery does vbulletin 5 currently use? jquery-2.1.4?
Vbulletin 5 & Jquery
Yes vB 5.3.1 uses jQuery 2.1.4.
You can change it in AdminCP under "Server Settings and Optimization Options" and use a different version but you have to test all the pages to make sure nothing is broken.Helpful? Donate. Thanks!
A user of my forum sayd there is an exploit for jQuery 2.1.4.
Are you aware of this? And what version do u use on this forum?
And do you use the following option?Use Remote jQuery jQuery script files are hosted locally on your server, you may however have them served from Google, jQuery, or Microsoft servers, saving you some bandwidth and potentially decreasing load times.
I'm not aware of an exploit until you mentioned it. Thanks for mentioning it. I googled it and found this:
Because of this jquery/src/ajax/script.js Line 18 in 250a199 jQuery.globalEval( text ); every text/javascript response gets executed. Even if we made a request to another service. CORS was created ...
Is that what you were referring to?
I don't think vB5 is directly affected as the exploit only occurs when you call $.get('http://othersite.com/blah.js') without specifying dataType and that external script returns malicious code.
vB5 doesn't call external scripts via AJAX at all by default. But if you have a third-party mod, your site may be vulnerable to that exploit if a mod calls external scripts that way.Helpful? Donate. Thanks!
They said they fixed the exploit in jQuery 3.x but I don't think that version is compatible with vB5. There are many breaking changes introduced in 3.x where jQuery methods that work in 2.x no longer work in 3.x.Helpful? Donate. Thanks!
Btw, did you report this exploit to vB, 420? This might force them to upgrade jQuery to 3.x sooner rather than later.Helpful? Donate. Thanks!
Reply to Topic Starter Ribbon for vBCloudby glennrocksvbThanks for reporting. I'll bookmark this post and check the issue.04-22-2024, 06:40 PM
