Member Ranks with links
    I have one rank for members that sets them apart as an expert in a certain field. It would be nice if the rank that is assigned to them is clickable, directing people to a page that would explain the rank.
    I tried using html for the rank, but while the image I pointed to shows up, the link added to the image it does not render for some reason.
    Can you post the html you're using?
      it has a hover description by default doesnt it? i was testing around with them for a time, but ended up disabling them...should be good enough for basic description at least but idk maybe you would need more.
        Yes, I need more. That's why I'm asking.
