Our forum is just over 20-years old now. There is A LOT of content, a very large amount of which is archived; hidden but accessible, but can't be added to (view only).
Much of what we have archived is no longer relevant; dead limbs on a still living tree. Is it possible to remove this old content and not affect the Thread/Post counts of our members? A Google AI answer says 'yes', but I'm not comfortable accepting its answer at face value.
AI Overview
Yes, you can remove forums in vBulletin and prevent affecting user post counts by first
moving or deleting all threads within that forum, then using the Admin CP to delete the empty forum, and finally running the "Rebuild Counters" maintenance task to ensure all counts are accurate. The key is to handle the content first and then clean up the container (the forum itself) and its counters.
Step-by-Step Guide
Delete/Move Threads:
Go to the forum you want to remove in the Admin Control Panel (Admin CP).
Use the moderation tools or a dedicated tool (like Node Tools in some versions) to delete all threads or move them to another relevant forum. This is crucial; an empty forum is easier to manage.
Delete the Forum:
Once the forum is empty, find the option to delete the forum itself (often under Forum Management or Site Builder in older versions).
Confirm the deletion.
Rebuild Counters:
Navigate to the Maintenance section in your Admin CP.
Find and run the "Rebuild Forum Information," "Rebuild Thread Information," and "Update Counters" tasks.
This step recalculates all post and thread counts across the entire forum, ensuring the deleted content and forum don't cause discrepancies in user profiles or forum lists.
Important Considerations
User Post Counts: Deleting the forum after removing its threads won't affect user post counts because the posts are already gone from the database. Rebuilding counters just cleans up the totals.
Permissions: Ensure you have administrator access and understand the moderation tools for your specific vBulletin version (e.g., vBulletin 4, 5, or Cloud).
Emptying vs. Deleting: If you just delete the forum without clearing its threads first, you might lose content or get errors, so emptying it first is best practice.
AI Overview
Step-by-Step Guide
Delete the Forum:
Rebuild Counters:
