Images display for different Usergroups
    Hi all,
    This is probably a reasonably easy fix for someone with more technical skills
    We have multiple usergroups with different access privileges
    I have a couple of usergroups where images are displaying on the forum vastly smaller than for a couple of others
    I have tried to mirror everything for the all the usergroups but I cannot detect why this is happening.
    Can anyone shed some light on what fields I need to adjust to get some consistency.
    Many Thanks
    Can you post a screenshot of images showing different sizes between usergroups? Do you have a mod that resizes images?
      Thanks Glenn
      This is the difference
        I have no idea why it would display different image size per usergroup. I would have to take a look at the page and inspect.
