Problem with ADs in vbulletin 5
    Hi everyone,
    sorry for my english.. i'm italian,
    I'm asking for help with a problem inserting advertising space from an agency.
    They provided me a script to insert on all pages that will call different AD formats based on the section the visitor is viewing.
    I inserted this directly from the style manager, and it works.
    However, I'm having problems with the section scripts because I insert them from "Edit Page" and I use the "AD" module to insert the script.
    These scripts aren't seen by the agency; it's as vBulletin isn't running them... do you have any suggestions?
    An example of a section script is as follows:
    <script>
    window._flux_config = {
        pagetype: 'forum',
        category: 'category_name',
        customTargeting: {
            "key1": "value1",
            "key2": "value2"
    </script>
    Which Ad location did you insert the script at? At the header, below the header or at the footer?
      Hi Glenn,
      I've inserted the main script in the header.
      I've inserted the module with the script that defines the different AD types, in a module under the global section.
      I've attached an image for clarification.​
      Thanks!!!
        If necessary, I'm willing to pay for help... as you know, glennrocksvb , I've already purchased two mods developed by you and I'm trying to continuously improve my forum...
        Thank you!​
          If it's ok with you, please grant me admin access to your forum so I can see how you set up the ad modules.
            I'll send you a private message. Thank you.
