Odd behavior
    Odd behavior
    Behavior observed in Safari and Firefox, so doesn't seem to be browser related. The selection list gets overlain by the bottom window border with the Search Result listing window is smaller (top to bottom) than the selection list.
    That's how it is even in vB6. It doesn't have a logic to calculate the available space and decide to show the dropdown at the bottom or top.
    If you want, you can set a max-height and display scrollbars if needed using custom CSS. But it will always do this even if there's enough space to display them all.
    .moderation-mainmenu .moderation-submenu {
        max-height: 200px;
        overflow: auto;
      Thank you. The 'only' time this would be a problem is if one needed to check an action that is hidden by the bottom window border.
