Vbulltin and Server
    Vbulltin and Server
    Hello
    I've a vps from godaddy
    1 vCPU core
    2 GB RAM
    40 GB NVMe SSD Storage
    But it hang all the time, and for example I'm not able do search rebilding in vbulletin.
    Do you think it's a server configuration problem or a hostingg service one?
    Thank you
    What error do you get when rebuilding search? Did you try doing it in command line?
      This's the message,
      for search rebuilding:
      1- When I reboot the server, it finishes around 85%.
      2- without rebooting, it finishes around 10%.
      and then hang.
        Check the error logs on the server to see the detailed error stack trace. I suspect it's timing out.
        It's better to do this using command line to avoid timeout.
          Here's php setting
          Memory_Limit was 128M, I changed it to 256M. But nothing change.
            Try doing it in the command line where no time limit is imposed.
              Would you please help me with this command?
                After a migration, a reindexation is recommanded. Since it is a long task, is there a way to do it with a shell command (php -f …). I would be able to launch it in a screen session and don’t worry about a laptop disconnection (power saver option…)
                There's a typo in that post. Instead of phpindex.php, it should be searchindex.php.
                  Your max execution time (30 seconds) might be low for an index rebuild if you've got a lot of post history.
                  Maybe temporarily raise that to 60 or 120 seconds and see if that helps?
                    Thank you, it seems a GoDaddy problem.
                    Here's the Server usage in 3 cases:
                    • Before restarting
                      CPU usage 15.5% /100
                      RAM usage 1.81GB /2GB (90%)
                    • After Restarting
                      CPU usage 78.03% /100
                      RAM usage 1.13GB /2GB (56%)
                    • After 15 minutes from restarting
                      CPU usage 13.68% /100
                      RAM usage 1.58GB /2GB (79%)
                    • After Around 30 minutes from restarting
                      CPU usage 9.83% /100
                      RAM usage 1.67GB /2GB (83%)
