Articles Content Management not honoring display order
    AdminCP > Articles > Content List
Name:	Screen Shot 2023-09-24 at 12.55.07 PM.png
    Our The Front Page > Articles
Name:	Screen Shot 2023-09-24 at 12.55.31 PM.png
    The ordering set in AdminCP isn't reflected in the Articles tab of The Front Page. Why?
    I checked the code in the widget_cmschanneldisplay template and the sort order is hardcoded to publishdate desc. There is a @TODO comment and code in the template that says "use this if we get the sort filter back" but the code doesn't include displayorder. Since they stopped development of vB5, sorting by displayorder will never be added. The same issue occurs on vB6 as the code in the template is the same.
      Thank you for looking into this.
        I found a way a solution but it requires editing the widget_cmschanneldisplay and adding the native usort() PHP function that is not allowed by vB to be used in a template. This function sorts the articles by displayorder. Upon saving the template, it will prompt that you are using what they term as "unsafe" function but you could ignore it and save the template anyway. Using usort() function in a template is safe and has no security implications. If you are okay with this, please let me know.
          There's actually a way to avoid using usort() directly in a template. You could move the usort() call to a custom API or controller that can be called from the template. Obviously, this will require a little bit of more code.
            I appreciate the offer, but this isn’t a deal breaker. Knowing why it doesn’t work is sufficient.
