How to modify the text post editor height?
    Is there any way to add more lines (higher) into the designed space for text input?
Name:	Screenshot 2023-07-31 at 2.54.40 PM.png
    The default height of vB5 CKEditor is 70px. That may be too short for some even if the editor "autogrows" when you get to the bottom and press Enter. To
      Thx Glenn !!
      This css_additional.css is getting beefy, LOL
        Rule of thumb - if an element is using a style variable, it is recommended to customize it using that style variable. Otherwise, use css_additional template to add custom CSS.
        In the above case for editor height, I don't think it's using a style variable.
