many thanks for your response. So I have no way of doing it myself. I once tried to rewrite the user SQL, but it went haywire. ok then I'll look for a provider that might create it.
Depending on your skills if you know the database structure of Woltlab and vB5 very well, then it's possible. But it's not just writing SQL queries. You may also need PHP coding for migrating passwords. I assume both systems use different password schemes.
