It's the other way around. Google does the indexing and not vBulletin. You can generate the sitemap on vBulletin and then submit it to search engines so they can index it.
The XML Sitemap specification allows search engines to index your site more efficiently. vBulletin 5 Connect can create the Sitemap automatically so you can submit it to your favorite search engines.
Our plugin can create sitemaps for the various sections of your website. That makes it easier for search engines to understand your site structure. We combine all of the individual sitemaps into a sitemap index. This means you only have to submit the sitemap index link which is automatically updated as you add, remove, or […]
I finally created a mod that allows you to add an icon to each post with options for sharing on other platforms. I honestly thought it was absurd that...
