Tapatalk large threads
    vBulletin Version:
    - 5.7.1
    PHP Version:
    - 8.1.12
    Database Version:
    - MariaDB 10.5.17
    HArdware
    MAria DB dual Xeon E 5260 V4 128GB ram 16 cores
    Issue Description:
    (Include error message(s), if any)
    - VEry slow large threads , query take several minutes
    this query for example was killed after running fo 5 minutes
    Database error in vBulletin 5.7.1:
    Invalid SQL:
    SELECT DISTINCT node.starter AS nodeid
    FROM AHOnode as node
    LEFT JOIN AHOnode AS starter ON starter.nodeid = IF(node.starter = 0, node.nodeid, node.starter)
    JOIN AHOclosure AS closure ON node.nodeid = closure.child
    LEFT JOIN AHOclosure AS exclude_closure
    ON (exclude_closure.child = closure.child AND
    exclude_closure.parent IN (16,30,33,20,9 ))
    WHERE node.contenttypeid <> 19 AND
    closure.parent = '2' AND
    node.nodeid <> closure.parent AND
    closure.depth <= 10000 AND
    node.inlist = 1 AND
    exclude_closure.child IS NULL
    AND (node.public_preview = 1 OR ( ( ( (starter.parentid IN (1,2,6,14,15,18,7,8,9,12,19,21,23,26,27,28,29,32,3 5,22,24,25,34) AND (starter.parentid IN (1,2,6,14,15,18,7,8,9,12,19,21,23,26,27,28,29,32,3 5,22,24,25,34) OR node.showpublished > 0)) AND (node.showapproved > 0 OR node.userid = 118067) AND node.viewperms > 0 ))
    OR starter.parentid = 9 AND node.userid IN (118067) OR (node.starter = 0 AND node.nodeid IN (1,2,6,14,15,18,7,8,9,12,19,21,23,26,27,28,29,32,3 5,22,24,25,34))))
    ORDER BY starter.lastcontent DESC
    LIMIT 50
    /** getSearchResults**/;
    MySQL Error : MySQL server has gone away
    Error Number : 2006
    Request Date : Thursday, November 10th 2022 @ 08:34:03 AM
    Error Date : Thursday, November 10th 2022 @ 08:38:05 AM
    Script : https://forum.motorguia.net/mobiquo....t_latest_topic
    Referrer :
    IP Address : 81.84.121.139
    Username : Icas
    Classname : vB_Database_MySQLi
    MySQL Version :
    Stack Trace:
    #0 vB_Database->getErrorData() called in phar://[path]/vb/vb.phar/database.php on line 1202
    Home vB_Database->halt() called in phar://[path]/vb/vb.phar/database/mysqli.php on line 236
    Forum vB_Database_MySQLi->execute_query() called in phar://[path]/vb/vb.phar/database.php on line 602
    #3 vB_Database->query_read() called in phar://[path]/vb/vb.phar/db/result.php on line 148
    Blogs vB_dB_Result->rewind() called in phar://[path]/vb/vb.phar/db/result.php on line 68
    Groups vB_dB_Result->__construct() called in phar://[path]/vb/vb.phar/db/querydefs.php on line 157
    Uncategorized Groups vB_dB_QueryDefs->getResultSetInternal() called in phar://[path]/vb/vb.phar/db/querydefs.php on line 140
    Special vB_dB_QueryDefs->getResultSetUnbuffered() called in [path]/packages/vbdbsearch/db/mysql/querydefs.php on line 601
    Visitor Messages vBDBSearch_dB_MYSQL_QueryDefs->getSearchResults() called in phar://[path]/vb/vb.phar/db/query/method.php on line 67
    Private Messages vB_dB_Query_Method->execSQL() called in phar://[path]/vb/vb.phar/db/assertor.php on line 245
    Albums vB_dB_Assertor->assertQuery() called in [path]/packages/vbdbsearch/core.php on line 467
    #11 vBDBSearch_Core->getResults() called in [path]/packages/vbsphinxsearch/core.php on line 498
    #12 vBSphinxSearch_Core->getResults() called in phar://[path]/vb/vb.phar/api/search.php on line 159
    CSS Examples vB_Api_Search->getSearchResultsCriteria() called in phar://[path]/vb/vb.phar/api/search.php on line 131
    Articles vB_Api_Search->getSearchResult() called in phar://[path]/vb/vb.phar/api/search.php on line 221
    #15 vB_Api_Search->getInitialResults() called in /var/www/html/mobiquo/mbqClass/lib/read/MbqRdForumSearch.php on line 64
    #16 MbqRdForumSearch->forumAdvancedSearch() called in /var/www/html/mobiquo/mbqFrame/mbqBaseAction/MbqBaseActGetLatestTopic.php on line 57
    #17 MbqBaseActGetLatestTopic->actionImplement() called in /var/www/html/mobiquo/mbqAction/MbqActGetLatestTopic.php on line 20
    #18 MbqActGetLatestTopic->actionImplement() called in /var/www/html/mobiquo/mobiquoCommon.php on line 102
    #19 MbqMain::action() called in /var/www/html/mobiquo/mobiquo.php on line 19​
    Affected Browser(s):
    Steps to Reproduce: Expected Result:
    Actual Result: (Include screenshot(s), if possible)
    Does this issue only happen in Tapatalk and not on the web version?
      YEs , and on very large topics.
      The query generated is huge .
      my board as almost 10M post, and some topics have 300 000 posts
      The vb4 as had no problems, but is was. simple structure.
      in Vb5 the joins are muche bigger
        I've seen this a few times in the last 2 months. I've restarted the db, but has since returned. Thoughts? Invalid SQL: /** saveDbCache */ SELECT * FROM vb3cacheevent WHERE cacheid IN ('node_494069_lvl1data'); MySQL Error : MySQL server has gone away Error Number : 2006 Request Date : Monday, February 18th 2019 @ 04:30:48 AM
