This 'feature' doesn't appear to actually be incorporated into the Editor; there isn't a button for it. How would it be written in the BB Code Manager?
You can't add noparse as a new BBCode in the BBCode Manager. It already exists internally. If you try to create it, it will say "There is already a BB code tag named 'noparse'. You may not create duplicate names.".
But you can create a new custom BBCode (e.g. [np] or whatever you want) that will work the same way as noparse. When you create the BBCode, select Yes for the following options:
Disable BB Code Within This BB Code
Disable Smilies Within This BB Code
Disable Automatic Link Parsing Within This BB Code
And of course, set Button Image option if you want the BBCode to appear in the editor.
