Hi
I had installed and configured two vbulletin 4.2.5 forums both of which worked perfectly on a webhosting
Now they both give this error, what happened? they both give the same error
Deprecated: The behavior of unparenthesized expressions containing both '.' and '+'/'-' will change in PHP 8: '+'/'-' will take a higher precedence in /home/xxxxxx/public_html/includes/class_core.php on line 5842
PHP Warning: Use of undefined constant MYSQL_NUM - assumed 'MYSQL_NUM' (this will throw an Error in a future version of PHP) in ..../includes/init.php on line 165
PHP Warning: Use of undefined constant MYSQL_ASSOC - assumed 'MYSQL_ASSOC' (this will throw an Error in a future version of PHP) in ..../includes/init.php on line 165
PHP Warning: Use of undefined constant MYSQL_BOTH - assumed 'MYSQL_BOTH' (this will throw an Error in a future version of PHP) in ..../includes/init.php on line 165
PHP Warning: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in ..../includes/functions_navigation.php on line 588
PHP Warning: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in ..../includes/functions_navigation.php on line 612
PHP Warning: Creating default object from empty value in ..../includes/functions_navigation.php on line 547
PHP Warning: Use of undefined constant userid - assumed 'userid' (this will throw an Error in a future version of PHP) in ..../includes/class_bootstrap.php(433) : eval()'d code on line 45
PHP Warning: mysqli_query(): (42000/1064): You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1 in ..../includes/class_core.php on line 1386
