disable comment on VB5 articles
    Hi
    Is there a way to disable the comment feature on articles to any user ?
    Usergroup Manager >> Registered Users >> has "Can Comment" is set as No.
    Users who are not logged on to the forum see "Posting comments is disabled."
    thank you
    Look in the channel permissions for the usergroup
      Hi NumNum
      within the channel permissions I cannot find CMS/Article category to change the permissions for the "Registered Users". I have found all the forum categories and the blog. Changed "Can Comment" to "No" for the blog, but this doesn't affect the Articles.
        What version are you currently using?
        In channel management/channel permission (5.5.6) it is labeled "Articles".
          Sorry for the late reply, I am on version 5.4.2.
            You should update to one of the latest versions.
