Hello all
I tried to insert in the additional css some codes but when running the forums none of them works. For example, the style I am using displays icons as a replacement for the navbar tabs. Each tab has an icon except for the new ones I create. When inserting the codes to use specific images in association with the new icons, they do not work. Nothing happens. The same problem happens after I pasted the code for round avatars.
What should I do?
Background information:
- Vbulletin 5.5.5. Candidate 1 (the did not work as well when the forums were vb5.4)
- I pasted the codes using both ways 1- suit builder 2- inside the edit template (in the style)
- I have a firewall installed on my hosted service (though I am whitelisting the IP and the codes do save in the additional css.)
Your help is appreciated.
What should I do?
