Some problems I have + Request some product
    Hi
    My brothers, I have several problems
    First problem with Usergroup Legend
    I installed it but it doesn't work so why?
    How do I add a sitemap in Google Webmaster Tools
    I also need a set of product working on 5.5.4 generation
    I want product decorations
    And product force members to view topic
    The product seals a distinctive seal is placed on the thread
    The product is authenticated with a trusted label
    The product quick switch between memberships
    Control of Navbar Lists
    And product vbseo_sitemap
    Waiting for help
    Waiting for help
      Originally posted by AnimeiatLight View Post
      Hi
      Waiting for help
      I do not have the usergroup legend, but have you verified you followed all directions in the install instructions?
      In your admincp under xmlsitemap you set up auto submission of site xml to google.
        Yes you have checked the installation steps and are correct prefer this is
        https://www.vbulletin.org/forum/showthread.php?t=288211
        Waiting for help
          You will need to ask that developer for assistance. It looks like support may have ended for that as the developer hasn't been online for 6 years.
            Well do you know code is doing the same thing
              There has been so much changed to the coding since version 5.0.0 that it probably needs to be re-written, IMHO.
                I would think that since it is based on usergroups it may be addressed via additional_css
                  I know that the code is placed through additional_css template but I don't know what the code is. thank you very much
