visible advertising by a user group
    Hello
    I need help with an addon or hack that allows us to display the ad pages on a specific group of users.
    thank you in advance
    ps: I know it's possible using the vbulletin conditions, but I do not know how to do it if a charitable soul wants to help me do it
    You can do this in the ad module via the site builder I believe, making it visible to certain groups.
    unless that is what you are referring to above.
      thank you for your reply
      I did not know how to do it, from where I ask for help
      thanks again
        Are you referring to vB4 or vB5?
          I have vb4 (VB 4.2.5)
            The above from me was referring to vb5 and will not work on vb4.
              unfortunately, it's sad
              my site is under vb4.2.5 and I really need this modification
              thank you very much for your answer
