This is a vB issue but this would only occur if you type very long words without spaces like you did. Try typing normal sentences and see if the issue still occurs.
Anyway, I tried replicating the issue on your site Mitch using my Android phone but I couldn't. Typing long words without spaces works as expected. It doesn't truncate the text. What iOS version are you on?
Good Day Glenn!! I implemented the above hook #1-#10. My font style and size changed when typing a reply to a post. Not sure if it also changed in other...
