API Auth in templates
    Hi,
    ME ... AGAIN ...
    This time, it's more straight up question (hopefully)
    I have this code in a widget :
    {vb:data IPresults, user, searchIP, '1', '2'}
    {vb:debugvardump $IPresults}
    <hr>
    <table>
    <vb:each from="IPresults.regipusers.1" value="RegIPs">
        <tr>
            <td>{vb:var RegIPs.username}</td>
            <td>{vb:var RegIPs.ipaddress}</td>
        </tr>
    </vb:each>
    </table>
    Of course, ignore the debug, it's just in a dev stage.
    The code works, if I'm logged in as admin, but only if I've confirmed my login (either via going into ACP or opening sitebuilder and confirming my password).
    2 questions :
    - Is this because it concerns this particular API call & data ?
    - Is there a way to give authorization to some other users than admin without giving ACP access ? (Either via code or via an ACP option)
    Thanks !
    So figured out that if you turn off the "inline moderation" setting in the Admin Control Panel, you get a different message.
    Right now, to be able to see the result of this query, you need to have the "Can administer users" option turned on for the specific user you are looking to give access to this info.
    I was wondering glennrocksvb is there any bypass, or possibility to sort of "set" this permission in a template ?
