Who's Online widget info
    Hi,
    Just looking to see if there might be a way to display username as well as avatar in this widget? I can only see the option of 1 or the other but I'm sure I've seen some VB5 boards that have both.
    Which Who's Online widget are you referring to? It shows the avatar and username at the same time.
    https://www.vbulletin.com/forum/online
      If we take the widget on the homepage here it only shows the avatars of those online but if you click into the Who's Online page (list) it gives username as well as avatar.
      I'm sure I've seen both on a homepage widget somewhere but I might be wrong. It could have been a Lithium forum.
        The "Recent Visitors" module on homepage here is a custom module I created.
        The "What's Going On" module is an existing vBulletin module.
        Both modules show avatar or username but not both.
        The "Who's Online" module which is an existing vBulletin module show both avatar and username.
