Thank you bro, it was a night mare, sorry for late reply, any referring to the forum on google were broken and links were not redirected to our forum after utf8 conversion, the problem was in urlident field in node table ((although it should not be a problem as all url identified with nodeid)), it is unresolved bug as vBulletin responded for someone before it is minor !!
Anyway, i was able to reconvert the urlident table outside mysql and restore it back and everything worked perfect!!
Thank you so much for your ongoing help and support
Good Day Glenn!! I implemented the above hook #1-#10. My font style and size changed when typing a reply to a post. Not sure if it also changed in other...
Today, 03:25 AM
