You can add custom footer using template hook system. There is a hook location called footer_before_body_end at the bottom of every page that you can utilize for it.
Correct. That is the proper way of doing it if it's possible. Editing existing vB templates may cause merge conflicts that need to be resolve every time you upgrade.
I am running a vBulletin forum for a content creator community and wanted to raise a mod request around Instagram media integration. Currently when members...
Yesterday, 09:14 AM
