please help, changed url in admincp by mistake and cannot login back !
    Hello,
    I have tried today to do some adventurous modifications to learn vb more !!
    but as usual failure !
    I have changed the url in admincp options, and saved by mistake., Now i can not log into admincp and i uploaded tools.php and it asked me to put in install folder inside the admincp directory. I did and it never worked
    I want to change the url in phpmyadmin manually, could that help?
    or how could you please help me solving this step by step instructions please
    Thank you
    You will need to follow these instructions.
    The tools.php file provides a number of powerful options that can help recover a malfunctioning vBulletin installation.
    • Blackhorse
      Blackhorse commented
      yess, it worked !!
      Thank you so much
    • NumNum
      NumNum commented
      Glad you resolved it.
