Bonjours a tous, m'as question et pour les visiteurs
je voudrais savoir au dois-je aller pour les option visiteurs et leurs donner les autorisation pour qu'il voient les sujets parce que la il voient juste le site,
If I understood your question correctly, you wanted to allow guests to view the content of all the topics in your forum. If that is correct, then try setting these 3 permissions to Yes for "Unregistered / Not Logged In" usergroup by going to AdminCP > Usergroups > Usergroup Manager and then editing the said usergroup.
I don't have that mod here. Where did you find it? You should ask the author of that mod on how to install and configure it. Doesn't it have a readme file containing instructions on how to install?
Description
Add an alphabetical filtering bar
Installation
1) Upload all files in folder upload to ther respective directories on your webserver.
2) Go to ACP / Plugins & Products / Manage Products and import product_alphabeticalfilter.xml
Uninstallation
1) Go to ACP / Plugins & Products / Manage Products and uninstall the product named 'Alphabetical Filtering'.
2) Delete the following folder
- core/packages/alphabeticalfilter
Have you contacted the author Forum Mods for help? You can just install it and check if it works in vB5.5.0. If not working, then uninstall it and then inform the author.
It uses primary_module_subheader_background stylevar but that stylevar is used in multiple places for multiple purpose. So you might not want to change it. To change just that category header, you need to add the below custom CSS in css_additional template in AdminCP or in CSS Editor in Sitebuilder.
I am running a vBulletin forum for a content creator community and wanted to raise a mod request around Instagram media integration. Currently when members...
Yesterday, 09:14 AM
