Hi all !
I would like to know if it's possible to use the Vbulletin syntax (like <vb:if condition=""> for example) inside a Php module added via the Site builder ?
Raw PHP is indeed working there, but Vb code isn't.
I saw that glen posted this useful answer there :
But I don't know if that apply to my case, I tried to add it, but I still can't get it to work.
My current test code is the following :
This is just, of course, to test the system and serve no other purpose as it is.
Thanks in advance
Cheers
global $vbulletin; echo '<b>test</b>'; <vb:if condition="$bbuserinfo['usergroupid'] == '1' OR '6'"> echo '<b>double test</b>'; </vb:if>
Thanks in advance
Cheers
